Condensadores 1900uF 250v compativel com 1900uF 150v?
4 participantes
Condensadores 1900uF 250v compativel com 1900uF 150v? Empty Condensadores 1900uF 250v compativel com 1900uF 150v?
Mensagem  ginjas 6/2/2012, 20:02
Boa noite a todos. Preciso de arranjar condensadores com esta referencia mas não está fácil.
Li na net isto:
Levinson 33H amp uses phillips capacitors. Also these inferior phillips capacitors were used in 331/332/333/334/335/336.
Levinson 33H uses four filter capacitors at 60000uf at 100V and two regulator capacitors at 1900uf/150V. When these phillips caps go bad you will get buzzing,distortion and amp shutting down etc. I recommend replacing these filter caps with cornell dubilier cap at 76000uf/100V. Three inches in diameter and 5.8 inches long. For regulator caps at 1900uf/250V. 1.39 inches in diameter and 4 inches long. You will hear a huge improvement in sound. And using a higher value filter capacitor helps the cap to run cooler.
Renjy651 (Threads | Answers | This Thread)
12-03-11: Renjy651
Just for the record the original Levinson 33H Filter Capcitors were made by Philips part# 3186FH603U075DPA2. 60000uf/75V.(2.5 inches in diameter and 5.6 inches long)
Cornell dubilier makes these caps at 2.5 inches in diameter. I recommend either 62000uf/75V also 68000uf/75V both very expensive since these caps are 2.5 inches in diameter.
Será que usando os 1900uF 250V não haverá problema? Estava a pensar usar os CORNELL DUBILIER - DCMC192T250AJ2B haverá outro semelhante em qualidade?
Onde poderei arranjar na europa ou asia?
Obrigado por qualquer ajuda.
ginjas
ginjas
Número de Mensagens : 953
Ocupação : artes gráficas
Pontos/Reputação : 550
Condensadores 1900uF 250v compativel com 1900uF 150v? Empty Re: Condensadores 1900uF 250v compativel com 1900uF 150v?
Mensagem  vinyl33 6/2/2012, 20:09
Podes encontra-los aqui:
http://www.ebay.de/itm/4x-1900uF-150V-SPRAGUE-Snap-80D192M150ME2D-Capacitor-/130147000893?pt=LH_DefaultDomain_0&hash=item1e4d5da23d
vinyl33
vinyl33
Número de Mensagens : 668
Idade : 69
Pontos/Reputação : 1160
Mensagem  ginjas 6/2/2012, 21:01
Obrigado pela ajuda mas precisava que fosse com aperto e de 35mm e isso não encontro só encontro com 250V mas será que é compativel?
é deste genero mas com 150v não encontro. Tambem li que é possivel substituir por 2100uF 150Vm será? Os originais são philips de 1900uF 150v…
ginjas
ginjas
Mensagem  rneiva 6/2/2012, 21:31
Se a tensão nominal do condensador for superior, como é o caso, não há problemas.
rneiva
rneiva
Número de Mensagens : 392
Idade : 62
Pontos/Reputação : 397
Mensagem  Mfigueiredo 7/2/2012, 10:34
Nos condensadores, a tensão que é indicada, significa que esses condensadores têm isolamento suficiente para suportar tensões ATÉ esse valor. Logo se o valor que precisas é inferior ao que encontras e TODAS as restantes características (capacidade, tipo, qualidade geral) são as adequadas, então não há qualquer problema.
Interesses : Música e o resto
Pontos/Reputação : 607
Mensagem  ginjas 7/2/2012, 20:22
Muito obrigado a todos pela sempre pronta ajuda sendo assim vou encomendar os 2100uF 150V. Boas musicas!
ginjas
ginjas
Mensagem  Mfigueiredo 8/2/2012, 10:09
Mas......
E há sempre um mas para nos enfernizar a vida.....Não achas que se o amplificador melhora assim tanto as perfomances qualitativas, os técnicos que o projectaram não viram isso, sendo assim tão fácil e óbvio?
Dá que pensar! Especialmente se os condensadores de origem ainda estão com as qualidades de trabalho a 100%.
Eu desconfio sempre de "engenheiros" que não conheço de parte nenhuma e se sobrepõem aos engenheiros que tiveram todo o trabalho e conhecimentos para projectarem máquinas tão evoluídas.
......Mas que las hay, las hay..........
Mensagem  ginjas 8/2/2012, 10:31
Alguns condensadores não estão a 100% e eu não encontro nada igual aos de origem (philips 1900uF 150, de aparafusar e de 35mm ø). Por isso é que estou a ponderar colocar com outras caracteristicas. Sim de facto não percebo porque não usaram estes superiores talvez ficasse mais caro será? Provavelmente os de gama acima usem uns melhores não sei…
Entre 1900uF 250v e 2100 150v qual acha preferivel usar?
ginjas
ginjas
Mensagem  rneiva 8/2/2012, 10:41
Si i valor nominal dos originais é de 1900/150, tanto faz usar os 1900/250 como os 2100/150.
Num caso aumentas a tensão e noutro a capacidade. O que não deves é cortar em nenhum deles.
rneiva
rneiva
Idade : 62
Mensagem  Mfigueiredo 8/2/2012, 17:30
Se forem de séries (qualidade) rigorosamente igual, eu usaria os mais baratos!
Mensagem  ginjas 8/2/2012, 17:59
Por acaso estava a pensar nos tais da cornell dubilier são caros mas pode ser que fique melhor que o original... Very Happy
Não encontro com as mesmas caracteristicas fisicas de outra marca.
ginjas
ginjas
Mensagem  ginjas 16/2/2012, 09:04
Não consigo encontrar cá na europa so nos eua mas só em portes… Crying or Very sad , alguem sabe onde encontrar? o que procuro é deste genero, com 35mm, 1900uF ou 2100uF com 150 ou 250V.
Muito obrigado por qualquer ajuda.
http://media.digikey.com/photos/United%20Chemi-Con%20Photos/E36D251LPN561TA54M.jpg
ginjas
ginjas
Mensagem  Mfigueiredo 16/2/2012, 09:59
Na Europa conheço:
Audioxcel, EuropeAudio, Mouser, RSAmidata, Hifi-Collective, Farnel e não me lembro de mais nenhuma, mas há certamente. Pode ser que encontres alguma coisa do mesmo nível de qualidade.
Eu não costumo prender-me muito às marcas.
No Canadá tens a Partsconnexion que também tem bom material e o preço dos portes é aceitável.
Nos USA conheço a Madisound e a Parts-Express.
Mensagem  ginjas 17/2/2012, 17:29
muito obrigado pela ajuda vou tentar. cheers
ginjas
ginjas
