HUM... o horrivel e odiado Hum... tem solução simples??
3 participantes
HUM... o horrivel e odiado Hum... tem solução simples?? Empty HUM... o horrivel e odiado Hum... tem solução simples??
Mensagem  targeting 3/12/2010, 12:55
O milagre do HUM no som , desvendado de uma vez por todas!
Quem é DJ ou usa de alguma maneira som pro , passa por isto a toda a hora HUMMMMMMMM.
https://www.youtube.com/watch?v=YyYb266R2-M
"I picked up an ebtech hum x because I've been getting a bad ground hum
when I hook up my tube reverb unit to my tube amp. Both have 3 prong
plugs. I didn't want to go with a plain old ground lift 3 to two
prong adaptor for safety reasons -- but it did work. The ebtech hum-
x also works fine, but I'd love to know how it does what it does. Any
techs out there willing to share?
thanks!!
The $90 Hum-X works *really* well. So well,
in fact, that most people think some heavy mojo
must be involved...but inside that slick little adaptor
is a very primitive (but clever) little circuit. In a
standard AC receptacle, you have three contacts -
hot, neutral, and ground. The hot and neutral lines
pass straight through the adaptor, although there's
a tap from the hot line (with a resistor) to power the
LED. The mojo is in the ground line, which has
a pair of 6A/1kV diodes between the wall ground
connection and the adaptor's output socket ground.
These diodes are connected in parallel, with
the anode on one diode connected to the cathode
on the other. (And vice versa, obviously.) The
pair of diodes has a 1K 1/2-W rsistor in parallel
with it; as far as I can see, this resistor serves
to produce a "correct" indication when an outlet
tester is plugged into the adaptor, since without
it, the outlet tester will give an "open ground"
indication.
In use, the adaptor is placed between the wall
outlet (or socket strip outlet) and the line cord
of the device you're powering. It breaks ground
loops, and does it well, without putting any screwy-
sounding isolation transformers in the audio
signal path. My key rig was buzzing like a beehive
before I put three of these between my keyboards
and the socket strip. They worked so well I was
intrigued, and decided to sacrifice one of the
devices to find out what was in it. The guts are
heavily potted, and it was difficult to reverse-
engineer; I had to carve the potting compound
away from the components with several different
types of knives - an X-acto, a utility knife, several
scalpels, a file or two, etc. It took quite awhile!"
Pelo que eu percebi este objecto é uma coisa simples.
Porque é que não existe cá á venda? Havendo tantos e tantos problemas que podem ser resolvidos com isto? Mas mesmo muitos problemas?
Isto é apenas corrente e mexemos é na terra... ora isso não faz mal nenhum.
Entendo pela descrição que para fazer isto em DIY, apenas é perciso isto:
- 6A/1kV diodes
Isto é suficiente para a nossa corrente 230v? Visto isto ser para o sistema americano 120v.
Não percebo é como é que é ligado á terra. Ou seja vem o cabo da terra da tomada do humx, ok.
depois são ligados esses diodos 6a/1KV em paralelo ... deduzo que sejam 6amperes e 1kilowatt de voltss? certo?
"These diodes are connected in parallel, with
on the other. (And vice versa, obviously)"
Aqui não percebo mas penso que algum electronico sabe o que é....e é apenas uma coisa básica... quem não sabe pergunta.
"The pair of diodes has a 1K 1/2-W rsistor in parallel
indication"
Quanto a isto pareçe que é desnecessário. Apenas para aparelhos de testes.
Quem ajuda nisto? Penso que isto é o santo GRAL que é perciso desvendar correctamente para 230v.
Para o que fazem estes diodos na terra ... e já agora para o que servem os diodos...
targeting
Número de Mensagens : 174
Pontos/Reputação : 182
Mensagem  jpinto 3/12/2010, 20:14
Se procurar na NET vai encontrar esquemas parecidos. Encontrei este que me pareceu bastante interessante:
http://sound.westhost.com/earthing.htm
É apresentado um esquema que utiliza uma ponte rectificadora em vez dos dois Diodos. A resistência não está lá só para os aparelhos de teste. No fundo este tipo de circuito é equivalente de certa maneira a desligar o fio de terra se a corrente que por lá passa é fraca e nesse caso os Diodos comportam-se como circuito aberto, quando a corrente na resistência aumenta e a tensão aos seus terminais ultrapassa a tensão de condução e este começa a conduzir forçando que a diferença entre as duas terras não seja mais do que, teoricamente, 0.6 V. A grande diferença é se houver um problema a terra é pior mas existe e no caso de isolar o fio de terra esta não existe.
1KV é um kilovolt isto é 1000 volts ou seja mais que suficiente para os nossos 230V.
Em minha opinião estes esquemas auxiliam na redução do HUM mas não creio que seja a solução sempre. Por exemplo o HUM provocado pela ligação ao operador de TV por cabo não deve ser resolvido desta maneira, mas sim isolar o cabo do operador, existem dois tipos de isoladores: capacitivo e transformador de sinal. O primeiro encontra-se no mercado a um preço muito barato mas pode não funcionar nos canais com frequência mais elevada o segundo não encontrei à venda em Portugal pelo que tem de ser encomendado nos EUA (http://www.jensen-transformers.com/datashts/vrd1ff.pdf).
jpinto
jpinto
Número de Mensagens : 265
Pontos/Reputação : 418
HUM... o horrivel e odiado Hum... tem solução simples?? Empty a mae de todos os HUMMMMMMMMMMM
Mensagem  Farmamen 8/12/2010, 01:33
Carissimos,
Defacto o Hummmmmmmmmmmmmmm tem sido um dos inimigos mais mortais do audiofilo.
Eu proprio luto constantemente. Basta uma pequena mudanca num cabo, num equipamento ou mesmo a posicao da ficha de alimentacao e HUMMMMMMMMMMMMMMMMM.
Ando con ideias de resolver a situacao. Pelo que pesquisei ha defacto uns conecoes ICE com filtro que podem ser aplicadas nos equipamentos, talvez uns nucleos de ferrite no cabo de alimentacao, mas segundo encontraei o ideal seria a aplicacao de um transformador com enrolamento 1:1 ( penso que se chama tranformador de linha?) entre a tomada e o equipamento.
Sendo talvez essa a derradeira arma mas com os inerentes custos, pois o transformador tem que ser dimensionado para o consumo do aparelho que se lhe vai ligar. E ha ai pessoal com cada bicho de amplificacao que pelo menos tera de ser de 500va.
Estarei certo ou errado?
Farmamen
Número de Mensagens : 7
Data de inscrição : 30/11/2007
Pontos/Reputação : 8
HUM... o horrivel e odiado Hum... tem solução simples?? Empty A mãe de todos os HUMMMMMMMMMMM
Mensagem  jpinto 9/12/2010, 11:51
Infelizmente não existe só uma Mãe ou Pai para todos os HUMMMM Crying or Very sad
O transformador de isolamento pode criar HUMMM para além de criar outros problemas, principalmente nos amplificadores de potência.
Quando aparece o HUMMM é necessário compreender de onde vem, o que nem sempre é fácil.
Algumas dicas:
1. A TV por cabo é uma das principais fontes do HUMM pelo facto de a terra deles não ser igual à da tomada. A solução é isolar a entrada do cabo de TV, infelizmente os isoladores no mercado Nacional não são muito bons se o sinal do cabo for suficiente os isoladores baratos funcionam caso contrário principalmente alguns canais das boxs deixam de funcionar.
2. Equipamentos ligados a várias tomadas, típico sistema HI-FI ligado a uma tomada e TV a outra existindo uma ligação entre os dois sistemas. Neste caso podemos considerar que ligar na mesma tomada resolveria o problema mas, infelizmente, pode não ser o caso. O uso de um cabo de alimentação comprido pode por si provocar o HUMMM pelo que se deve ter em atenção a qualidade do cabo.
3. Cabos de sinal enrolados e perto de fontes de alimentação são uma fonte de HUMMM por indução. As ligações balanceadas tendem a ser mais imunes, mas o melhor é não enrolar os cabos e ter em atenção por onde passam.
4. Ter em atenção a qualidade dos cabos de alimentação, fichas triplas, etc.
jpinto
jpinto
HUM... o horrivel e odiado Hum... tem solução simples?? Empty Re: HUM... o horrivel e odiado Hum... tem solução simples??
