NewClassD discrete OPAMPs
Mensagem  Convidad em 18/6/2010, 13:06
Mais uma maravilha de Opamp´s !!!
Most signal sources and many power amplifiers use operational amplifiers, as their main active component, being used for amplifying, filtering and impedance conditioning of the audio signal. This means the audio properties of these OPAMPs have a powerful effect on the sound of your audio appliance. Even OPAMP's with good data, like very low THD specification still have very different sonic properties. This tells us that the technical specification alone is not the defining factor for sound quality.
Classically there has been a few IC OPAMP's considered good for Audio, and with golden qualities. But today it is in debate if even these very expensive chips are really capable of getting the best sound out of your CD player, DVD player, preamplifier or power amplifier. Also, when you add the fact that most commercial audio players use cheap OP-AMP's.
The NewClassD discrete OPAMPs are based on a novel 12 transistor circuit with very high linearity. Therefore low open loop amplification is possible, leading to natural, relaxed sound with a very high detail and perfect tonal balance. The circuit implies current mirrors, which are implemented with ulra low noise green LED's. This gives the amplifier very good low noise performance.
The input stage is bipolar unlike some other discrete OPAMP's available on the market. This gives our module the best possible stability under all real-life uses, and also gives improved protection against static electricity. Bipolar transistors also tend to sound cleaner and more dynamic than FET's in the input stage.
It will drop directly into DIP8 single or dual footprints in a CD, DVD, Preamp or soundcard. It's based on brand new technology, which will provide world class sound performance in your existing product. Compared to other existing products this module is made with low inductance non magnetic components, and a special high-speed circuit with extremely low THD (0.0003%). Current mirrors are made with the lowest noise LED references. Resulting in a clean and coherent sound experience, with complete 'black background'.
Re: NewClassD discrete OPAMPs
Mensagem  Carlomar em 24/6/2010, 20:08
Obrigado,
Isto interesa-me.
Na tua opinião como os comparas com os Burson Audio?
E os Sun Opa V2 Stereo Opamp, chegaste a mandar vir?
Última edição por Carlomar em 24/6/2010, 22:33, editado 1 vez(es)
Carlomar
Número de Mensagens: 490
Data de inscrição: 03/09/2007
Pontos/Reputação: 930
Mensagem  Convidad em 24/6/2010, 22:09
Caro Carlos, os Burson são EXCELENTES e o melhor que já ouvi até hoje, mas estes são novos e ainda por cima são bipolares e a topologia difere dos que conheçemos.
E como estou bastante curioso , pois dizem maravilhas destes ClassD.
Mensagem  Carlomar em 24/6/2010, 22:36
Quando tiveres resultados mais concretos avisa.
Já agora, costumas solda-los directamente ou usas suportes?
Carlomar
Mensagem  Convidad em 24/6/2010, 22:49
Soldo sempre suportes para nunca mais necessitar de soldar mais nada e depois é só rodar opamp´s
Mensagem  Carlomar em 27/6/2010, 19:15
Vodoo,
Eu e um amigo testamos ontem pela 1ª vez um Burson Audio duplo, mas a coisa não correu muito bem.
Primeiro as ligações dos mesmos não entram nos suportes maquinados.
O pior foi na audição em que os mesmos parecem tocar muito bem, mas com um ruido de fundo forte que não é normal.
Ao olharmos para as duas placas que compõem cada uma um circuito, notamos que numa delas falta uma resistencia de 10k(R8). Á partida deveria ser as duas iguais.
Por causa destes dois problemas o mesmo vai ser devolvido.
Só por curiosidade, poderia ver nos seus se as duas placas são exactamente iguais?
Carlomar
Mensagem  Convidad em 27/6/2010, 21:03
Amigo Carlos no meu caso são as duas aparentemente iguais, esse de certeza já vinha mafiado !!!!
E ruído no meu duplo é coisa (quase) nula , e tocam maravilhosamente
