Full range Visaton B200
Promoção
Preço por unidade 121,30 euros
Vários projetos
http://www.visaton.de/en/bauvorschlaege/breitband/index.html
Solo 50
http://www.visaton.de/en/bauvorschlaege/breitband/solo50/index.html
Technical Data:
Rated power 40 W
Maximum power 70 W
Nominal impedance Z 6 Ohm
Frequency response fu–18000 Hz
(fu: Lower cut-off frequency depending on cabinet) .
Mean sound pressure level 96 dB (2,83 V/1 m)
Opening angle (-6 dB) 48°/4000 Hz
Maximum linear displacement +/−3,5 mm
Resonance frequency fs 40 Hz
Magnetic induction 1,2 T
Magnetic flux 755 µWb
Height of front pole-plate 8 mm
Voice coil diameter 25 mm
Height of winding 4 mm
Cutout diameter 190 mm
Net weight 2,16 kg
D.C. resistance Rdc 5,0 Ohm
Mechanical Q factor Qms 8,39
Electrical Q factor Qes 0,83
Total Q factor Qts 0,75
Equivalent volume Vas 102 l
Effective piston area Sd 214 cm²
Dynamically moved mass Mms 9,7 g
Force factor Bxl 3,9 Tm
Inductance of the voice coil L 0,5 mH
Vários projetos
Solo 50
Technical Data:
Rated power 40 W
Maximum power 70 W
Net weight 2,16 kg
megaudio- Profissional
- Número de Mensagens: 68
Data de inscrição: 15/03/2009
Pontos/Reputação: 66
Tópicos similares» [ VST ] Softube Trident A-Range VST.RTAS.v1.0.2-AiR [ 11 MB ]
» Guia: Assassin Cross full PVP / SB !
» servidor cs sky full (cswat@hotmail.com.br)
» GUIA MESTRE FULL ASURA
» tibia Auto crack 9.44 Tibia bot ng 9.44 FULL CRACKED neobot 9.44 + tibia auto 9.44 + PYTHON 24 bbot 9.44 tibia cam 9.44
