Venda colunas Monitor 890 MKII VENDIDAS
Mensagem  megaudio em 10/5/2010, 18:26
Colunas Megaudio 2001.usadas (retoma)
preço 1600 euros
Preço do Kit sem caixas 3664 euros
Identicas ás Visaton monitor 890 MKII.Alinhamento da unidade de agudo diferente
Rated power600 W
Maximum power900 W
Nominal impedance Z4 Ohm
Frequency response30–35000 Hz
Mean sound pressure level94 dB (1 W/1 m)
Cut-off frequency800/7500 Hz
Principle of HousingBassreflex
Net volume180 l
Outer dimension height1070 mm
Outer dimension width688 mm
Outer dimension depth508 mm
Extract from Image HiFi (MK II)
"The Monitor 890 MK II deals beautifully with the full range even down to even low output levels provided the listening area is not too small. The excellent mid-range horn reproduces voices and non-amplified instruments beautifully without the slightest over-emphasis and right across the frequency range. The full range of tonal sophistication is remarkably well differentiated for a horn-based system, and this with a clarity and dynamism that is missing in less powerful drivers. We were pleased to find that, provided the output level is well chosen, the high-range horn does not stand out on its own as a fragment of the picture but blends in well to the impressive overall panorama."
"This combination of pure power and sophisticated manners was what irresistably attracted me to the Monitor 890 MK II."
Verdict: excellent
Extract from STEREO (MK II)
"... this chunky character pounds out bass levels that make a lot of other speaker systems look pretty puny. The sounds washed around our ears precisely but unmistakably and very powerfully. It was enough to make you whince. But this Visaton model does not overdo it. The bass production is well balanced against the higher ranges to produce a tidy overall picture where the bass does not have trouble keeping up. The high range retains an airy feel and is very clearly defined. The horn's response and depth of sound are excellent, and its spatial positioning is a dream."
"The Monitor system can produce disco music just the way the kids like it, can make the walls of your nearest castle vibrate with Pink Floyd or some good organ music and yet it is still a real treat to listen to a symphony on the same speakers. This precarious fine line between hi-fi and professional speaker system has been very well mastered."
"Visaton's Monitor speakers are mor than just a pleasant sensation. They combine the typical strengths of a horn system like sound pressure and temperament with such features as accuracy of depth and allround abilities brillinat!"
Verdict: excellent
Extract from Klang & Ton (MK II)
Provided you have enough space and a very tolerant partner, we can warmly recommend this major contribution to the art of building speakers to every aficionado of lively guitar-based rock through to subtle and sophisticated rhythm & blues. Although the Monitor set-up is perfectly capable of reproducing classical musical and can cope with lower volume ranges, its strength is definitely in the excellent representation of live-sounding events, full of temperament and dynamism.
megaudio
Número de Mensagens: 68
Data de inscrição: 15/03/2009
Pontos/Reputação: 66
