Os meus "novos" Giras
Página 6 de 16 • Compartilhe •
Página 6 de 16 •
1 ... 5, 6, 7 ... 11 ... 16
Re: Os meus "novos" Giras
Já falei com o ingles e vem um cabo original da Linn por mais 25 libras. Vamos ver se ja tenho o material no final desta semana.
JCF- Membro Audiopt
- Número de Mensagens: 350
Data de inscrição: 06/05/2009
Pontos/Reputação: 429
Os comentários aqui neste site não são animadores.
Linn
This may
come as a surprise to some of you, but the Basik (LV X) and the Basik
Plus (LV X+) arms were something less than overwhelming when they came
out and by today's standards are very outdated. It was Linn's answer to
requests made by dealers that wanted a cheap and cheerful arm and cart
to go with the LP12 mostly to keep it within a certain price range. If
you are looking at a buying a good player with this arm second hand you
should factor in that you will have to change the arm to get the most
out of you turntable, even a second hand Rega 250 will be a big
improvement, and if you are buying from a dealer it might be worth a
try to get him to offload the arm for you (there is plenty of Linn
freaks out there that will buy almost anything with that name on it,
esp. here in the UK, and ANY type of Linn arm will fetch at the lest as
much as a Rega so you will). If you are dead set on a Linn arm you
should note that the Akito that was introduced slightly later than the Basik+ is much better and can be found used for a similar price.
http://audiotools.com/oldarm.html
Já o comprastes?
Linn
This may
Já o comprastes?
O problema é que o preço semelhante é... praticamente o dobro.
Em todos os equipamentos ja se sabe, aparecem opiniões divergentes.
Só não sei se estou a fazer bem em comprar porque estou a gostar MUITO do Thorens e não sei se vou gostar tanto do Systemdek. Para ser franco a minha vontade era vender ambos e arranjar um Thorens 160 mais recente desde que em excelente estado.
Vê este negócio no eBay 320446331746 so tem o eventual defeito do braço Linn Basik. Neste momento estão mais dois em leilões a terminar...
JCF- Membro Audiopt
JCF escreveu:O problema é que o preço semelhante é... praticamente o dobro.
Esse que mencionas, já acabou.
Não seja por isso
170403438936
Este 330374732171 acabou hoje sem licitaçoes...
170403438936
JCF- Membro Audiopt
JCF escreveu:Não seja por isso![]()
170403438936
Está muito bonito sem duvida. A ver se paras de comprar pratos, senão temos que te levar a uma instituição para a recuperação de pratodependentes.
António José da Silva escreveu:JCF escreveu:Não seja por isso![]()
170403438936
Voltando atras. Eu sei que o Akito é melhor mas tenho-o visto por valores a rondar as 220 libras e por esse preço provavelmente até optaria pelo Jelco novo.
A razão de optar pelo Basik plus é que o meu Systemdek tem armboard para Linn e torna-se mais facil adaptar um braço da marca. Claro que podia arranjar uma armboard nova para Rega e comprar um desses RB 251 OEM, nem é muito caro. O que me esta a preocupar é o braço ser mais leve que contava e eventualmente demasiado leve para a Denon DL-160 que tem uma compliance bastante baixa e ainda por cima é bastante leve.
Agora é esperar que o material chegue, montar o braço e a celula, ver se tem folgas ou algo que precise afinar, fazer um alinhamento aproximativo que é o que dá para fazer com os meios que tenho e começar a ouvir. A Denon é nova e praticamente não rodou.
JCF- Membro Audiopt
JCF escreveu:Cá vão as primeiras fotos do menino:
Por acaso estou com muita esperança de por este GD a tocar muito bem com a ajuda dos especialistas do forum
Espetacular este gira!!!
Como fiquei com inveja, mandei vir um do ebay igual a este
. Não há-de haver problema, com tanto especialista por aqui!!!GOsto muito e por ser tão invejoso, depois também vou querer um thorens, mas vamos com calma, senão o orçamento não aguenta
InThaVines- utilizador iniciado
- Número de Mensagens: 108
Idade: 32
Data de inscrição: 28/05/2009
Pontos/Reputação: 124
Qualquer dia temos que criar o clube "Sistemdeck", a julgar pelo nº de users que estão a aderir ao mesmo
Ps: Eu tambem acho o giradscos bem bonito
mn61- Membro Audiopt
- Número de Mensagens: 3031
Interesses: Hi-Fi-Desporto
Pontos/Reputação: 2075
E a culpa é do AJS que anda a instigar a malta a comprar Systemdek's
O meu braço "novo" já vem a caminho, é este 220506132722
Quando tiver o braço e cabeça montados temos de fazer uma acariação de Systemdek's para ver qual toca melhor
JCF- Membro Audiopt
JCF escreveu:![]()
E a culpa é do AJS que anda a instigar a malta a comprar Systemdek's![]()
Por cada Systemdek vendido no mundo, eu recebo a minha percentagem.
Fora de qualquer brincadeira, só o aconselho porque o acho muito bom. Até há quem o ache digno de um SME V.
Portanto.....
António José da Silva escreveu:JCF escreveu:![]()
Por cada Systemdek vendido no mundo, eu recebo a minha percentagem.![]()
Portanto.....
António, já que fala nisso faço-lhe uma questão...a minha "encomenda" vem com um braço Systemdek que o vendedor diz ser fabricado pela Jelco, que já aqui mencionaram, será que o braço é bom ou nem por isso?
Idade: 32
InThaVines escreveu:
O que está no Systendek do Manel é um Jelco e eu fiquei muito bem impressionado com aquilo que o conjunto é capaz de fazer.
E é capaz de muito.
E já agora, a célulaAntónio José da Silva escreveu:InThaVines escreveu:
O que está no Systendek do Manel é um Jelco e eu fiquei muito bem impressionado com aquilo que o conjunto é capaz de fazer.E é capaz de muito.
é uma nagaoka mp11?!?!?! Nunca ouvi falar
Idade: 32
Em relação à qualidade do braço não me vou pronunciar,porque nunca o comparei com outros....agora quanto à configuração do mesmo, pessoalmente prefiro estes braços curvos aos que são todos direitos.
Página 6 de 16 •
Tópicos similares» Fanzine "A Saga dos Deuses - Cap.1: Os Lendários Anjos Solares"
» Tarte de Legumes - Revista "Momentos de partilha"
» Alguns desenhos meus ^^
» os meus trabalhos em ponto cruz (Vanessa) actualizado em 13/8/2011
» novos temas de conversa!
Página 6 de 16
