Como limpar um LCD
Como limpar um LCD
Mensagem  pbarata em 4/7/2007, 20:12
Ora, aqui está uma receita para uma mistela barata e eficaz.
How to Properly Clean your LCD Screen
When it comes to optimize the layout of your office space, nothing helps to free desk space more then a nice, flat LCD screen. That's probably one of the main reason everyone has one these days. Apart from that, they're also very cheap, easy on the eyes and consume less electricity than their CRT counterparts. With all that said, there’s really no reason not to have one sitting on your desk in 2007.
But these screens are not perfect. In fact, you have to be very careful when cleaning them up. Too much pressure using the wrong kind of cloth will most likely scratch your display and could even burn some of its pixels. So the question is, what is the proper way to clean an LCD screen?
First, you've probably seen some of those expensive LCD cleaning solutions in computer stores right? The good news is that you don't really need these. Mixing up your own cleaning solution is very easy and will actually save you quite a few bucks. You only need 2 ingredients:
* 70% Isopropyl alcohol (Warning)
* Distilled Water
The recipe is easy: Mix the Isopropyl alcohol and distilled water in equal parts (50/50) inside an empty Windex-like bottle. Do not use tap water! Doing so will leave white smears on your screen after cleaning it up because of the dissolved minerals inside the water. When finished mixing, just close the bottle using the "spray" adaptor that comes attached to it.
Next, you will need to find a good, soft piece of microfiber cloth (3M) to clean your display. Avoid paper tissues at all cost! Using those on your screen would be just like scrubbing sandpaper on it and may scratch it permanently. You wouldn't want to do that right?
Now that we have everything we need, start by turning off your screen. Dampen your piece of soft cloth with your cleaning mixture and then wipe the display gently from top to bottom. Never spray liquid directly onto the LCD. When you're done, wait a few minutes to let your screen dry, and then turn it back on. Voila, you're done! Your screen should now be sparkling clean.
And if you absolutely want to use a product that was specifically made to clean LCD screens, PixelClean makes an excellent LCD cleanerthat is quite effective and not too expensive.
(Retirado de: http://geeksaresexy.blogspot.com/2007/01/how-to-properly-clean-your-lcd-screen.html)
Pixelclean:
http://www.amazon.com/PixelClean-Deluxe-LCD-Screen-Cleaning/dp/B000J2D902?ie=UTF8&s=electronics&qid=1176689828&sr=8-1
pbarata
Número de Mensagens: 1074
Data de inscrição: 08/06/2007
Pontos/Reputação: 377
http://www.WhoAmI.net
Re: Como limpar um LCD
Mensagem  Tomas em 22/6/2010, 18:39
Querem a minha opinião, não faça, nada disto.
Vão ao Jumbo e somente ao Jumbo, porque os outros não têm, e compram um pano anti-estático, depois compram numa conhecida casa em Lisboa um spray tipo espuma (mandem PM que eu digo qual é a casa)...e NADA DE ALCOOL!!!!!
É um conselho....
Tomas
Número de Mensagens: 29
Idade: 34
Ocupação: Empresário
Interesses: Cinema; Automóveis
Data de inscrição: 27/04/2010
Pontos/Reputação: 69
Mensagem  Blink em 22/6/2010, 21:15
Tomas escreveu:Querem a minha opinião, não faça, nada disto.
É um conselho....
Caro forista mencionou o nome Jumbo pode mencionar o nome da casa do tal spray, aqui não há segredos comerciais.
Número de Mensagens: 4216
Pontos/Reputação: 1629
Mensagem  Tomas em 22/6/2010, 22:22
Também é verdade... LOL
O nome da casa é Maquimsom. Fica em Povoa de St. iria.
Custa 45 Euros, mas dura uns 2 anos...Não ha melhor e eu sou muito minucioso. Tenho um Pioneer Plasma e só uso isso.
Tomas
Idade: 34
Mensagem  Orion em 22/6/2010, 23:11
Tomas escreveu:Também é verdade... LOL
Também ando há muito tempo para arranjar algo superlativo para limpeza do meu pioneer kuro e, alcool nunca arrisquei. Vou tentar essa recomendação e ver .
Número de Mensagens: 4208
Pontos/Reputação: 2215
