Directório de marcas de gira discos - G a O
Galibier Design
Makes 2 high end designs namely the Quattro ALU and the Quattro Supreme. These look to be partly derived from the Teres design but look quite a bit more refined, both feature plinths milled from solid aluminium, utilise battery driven DC motors and can accommodate 2 armboards/arms in addition to allowing you to choose between a vinyl or a Teflon/Aluminium platters. The Supreme is identical to the ALU except that the plinth has machined vibration damped chambers and is stiffer. The company also sell turntable parts for those of you interested in DIY turntable construction.
Garrard - ver --> Garrard/Lorricraft Turntables
Gemini
Makes a large range of DJ Turntables, in fact many more models than are shown on their homepage, I suggest you get a hold of their catalogue either through a dealer or via one of the downloadable PDF files on their homepage. They also have one model that is more a home deck, it's the XL-100 that typically retails for less than USD 100 in the states.
Gem Sound
Makes a small range of DJ turntables.
GLI
Manufactures low/mid priced DJ decks.
Goodmans
Make the GSP 400 turntable with built in RIAA preamp, one of the cheapest models on the market. Also has at the least one model of a midi music system that has a built in turntable.
Goldring
Uk manufacturer of pickups, turntables and other vinyl related wares, with a good reputation in all the products.
Hifine
Makes 2 turntables, the Prajna is a rather light belt driven design with an acrylic platter, it comes as standard with a Rega RB 300 Tonearm and does support 78rpm playback (by moving the belt), they also make the heavier string driven Tao turntable that features a base made out of Granit or Marble, has a tonearm base made out of Messing and comes standard with the Helius Cyalene tonearm, the Tao also supports 78rpm.
Immedia
Makes a high end turntable called RPM.
Has a range of DJ turntables starting with the budget belt driven DJP-100 that amongst other features has a +-7% pitch control, the slightly more expensive DJP-122 has a stronger motor and a more accurate motor control (meaning a faster start times etc.) and -+10% variable pitch, there is also a variant called DJP-122 SI, The top of the line model is the DJP-202 and the DJP-202 SI variant, these units have a much stronger motor that the 122 and are direct Drive, more info on these models here.
Jaytech ver --> Reloop DJ Turntables
JB Systems
Makes a range of mid priced DJ turntables.
KAB USA
Modifies Technics turntables for use for archivists and 78' enthusiasts.
Kenwood
Make the P-110 a budget automatic turntable with built in RIAA preamp intended to mate with Midi systems and suchlike. They make 2 more conventional models that appear to be made especially for export markets in North America, namely the KD-291RC and the slightly more upmarket KD-492FC. It seems that the company does not supply those turntables to the European market, there was for a short wile a model available similar to the P-110 but it appears to have been discontinued in 2002.
Klangtraum
This company makes one model of a turntable called the DL-2, it more conventional in looks and smaller than most other German tables but is made out of advanced composite materials and is heavier and more solid than it looks.
Kyocera
Kuzma
This manufacturer has an interesting lineup of high end turntables. Their range starts with the Stabi S a resonably priced deck (for this kind of performance , next in line is the Stabi, a more tradidtional suspended turntable in a heavy wooden box, then comes Stabi Reference a more usual high end heavy platter turntable (40 kg total), but the cream of the crop is the Stabi XL that counts in at a whopping 77 kgs. and has to be seen to be believed, one of the best turntables in the world.
Lenco (STL)
This brand is now licenced by the Dutch STL/Supertech group and has no relation to those old Swiss Lenco's but nevertheless they make the L-3081 a very low budget belt driven semiauto turntable and the L-3086 version of it which sports a built in phono preamp. They also make a budget DJ turntable called the L-3807 which sports a direct drive motor, +-8% pitch control and a light built into the tonearm.
Linn
Linn still makes the legendary Sondeck LP12 in at least 3 variants, but is starting to look increasingly dated next to the more modern and innovative designs from central Europe. The main difference between the models in the Linn range lies in the power supply shipped with the models and this means that they are upgradable to a better spec at a later date, and an alternative to the options that Linn offers in the Naim Armageddon power supply.
London Acoustical Developments
Lorricraft
Make the 501 model, a new design "inspired" by the Garrard 401 in other words the only idler wheel driven model currently on the market, in addition they also rebuild and sell old 301 & 401 models in and provide support and spares for them (but not for other Garrard models). See the section on Older Garrard turntables here further info mods and plinths etc for older models.
Loth-X
Makes the mid range Othello and the high end Aida turntables.
Marantz
Make one deck
Mel Audio
Makes a high end table called Go-El.
Michell Engineering
Makes the Gyrodec and Orbe, high quality turntables that go for a reasonable (as opposed to bargain) price. Highly recommended. Also has a bunch of upgrades for their older models and an interesting range of accessories. The Orbe is reviwed here, but their cheaper Orbe SE has been getting even better reviews recently.
Micro-Seiki
A Japanese manufacturer of turntables, used to manufacture mid and high end turntables and electrostatic headphones of almost legendary quality in the seventies and eighties but turned to the manufacture of high end and reference class turntables in the 90's. Company ran into trouble in the late 90's and stopped making turntables and providing spares for their older products in 1999 with the exception of a high end variant of the 8000 turntable that was made to order well into 2001, the company still exists as a precision engineering workshop (much like competitors Avid Hi-Fi and SME ltd. funnily enough, but smaller) but no longer seems to be willing or able to supply turntable products.
Morsiani
Makes reference class turntables to order.
Music Hall Audio
This company has for some time sold Pro-Ject Turntables under their own name, initially they were mostly just rebadging jobs and thus were not listed separately from the Pro-Ject designs but later models have varied from the original designs, some just a bit but others quite considerably, apparently in order to suit American tastes so it's prudent to list them separately. The cheapest models from the company is the MMF-2.1 which appears to be the Pro-Ject Debut base with the tonearm from the Pro-Ject 0.5 i.e. a simple but effective plinth with a quite reasonable arm, the table is supplied with a choice of 2 Music Hall branded cartridges called the Tracker and the Magic but these appear to be rebadged versions of Goldring Elan and Goldring Electra. The next deck up is the MMF-5 and but that deck is were things start to differ from their Project counterparts, while the basic deck is really Pro-Ject 2.9 the isolation is not only provided by feet as with the 2.9 but by adding a base of similar dimensions as the plinth which is decoupled from the plinth via the use of 6 rubber springs/cones, the motor and power switch are mounted in this base thus isolating them from the plinth. Other features of the deck are the same as the 2.9 model from Project except that a Goldring 1012GX cartridge is fitted as standard, there is a variant available called MMF-5SE that in addition to the above has a reel wood veneer, adjustable conical feet, isolation uses Sorbothane rather than rubber and a Goldring 1022GX cartridge is fitted as standard. There is a review of the MMF-5 to be found here. The MMF-7 has same basic plinth construction as the MMF-5 with the spiked feet and Sorbothane isolation used in the SE version, the tonearm is the Pro-Ject 9 Tonearm and the motor and the acrylic platter are connected via a perimeter belt, unlike the cheaper models the MMF-7 usually comes with no cartridge fitted as standard but the Goldring Eroica H can be had fitted at a discount price. The MMF-9 is a curious design, it blends the plinth design from the MMF-5/7 with the guts of a Project RPM-9, in this case the deck has a plinth and base and an intermediate base all being decoupled from each other by 4 Sorbothane springs, otherwise the technical features are the same as with the RPM-9, the deck is supplied without a cartridge although you can get it with a Music Hall Maestro high output MC cartridge at a discounted price.
Musical Fidelity
Makes a deck high end
Nad Electronics
Makes the 533 turntable, a unit that is well regarded but not as much of a bargain as it used to be.
Nakamichi
Japanese manufacter
Nottingham Analogue
Has a well regarded lineup or record players in the dearer end of the spectrum, including the Spacedeck, Hyperspace and Interspace. Since the company does not have an Internet presence it's perhaps best for you to go to their distributor for further info on their range, but resources available there include high resolution pictures and setup booklets in pdf format etc.
Numark
Makes a range of specialised DJ turntables and associated products, perhaps their most interesting product is the PT-01 which is a portable record player, while it is in most way's similiar to all other portables with a somewhat less than audiophile sound not the least due to the cheap built in speaker it has a couple of uniqe features that can be traced back to the fact that the basic turntable and arm combintaion has it's origin in a budget DJ deck rather than a record player for dirt cheap music systems like most of it's competitiors. This menas that the deck supports the playback of 78 RPM records (you will have to procure the appropriate stylus though), it has a 20% variable speed (10% either way) and a built in stereo RIAA preamplifier that is not only connected to the internal amp/speaker but to a stereo line out and headphone output, the preamp is not defeatable so some 78's may sound a bit odd when played on this device although the simple tone control provided will go some way towards correcting that. The tonearm compensatin is static though so while you can repalce the pickup it can only accomidate MM designs with the excat same or very similar compilance specifications. There is one further oddity with the PT-01 however and that is that the line out level is controlled by the onboard volume knob, by all reports that the sound is avove average for such a product.
Omnitronic
Has a large range of quartz controlled direct drive DJ decks that have high torque motors including the D3120 that supports 78 rpm in addition to the usual, has an electronic braking system and a +/-20% variable pitch control..
Optimus ver --> Radio Shack Turntables
Opera Audio
Manufactures the suspended Reference LP-1.0, a high end string driven model that is usually supplied with one armboard but can actually accommodate 3, the motor and electronics are in a separate housing from the table itself to minimise vibrational and electronic interference, they have recently introduced an upgraded model called the Reference LP-2.0 but will continue to supply the older version at slightly .
Oracle
Still make an updated version of the Oracle turntable that made waves in the early 80's.
Origin Live
Manufacture turntables, turntable kits & accessories in the mid to high price range.
Gemini
Gem Sound
GLI
Goodmans
Goldring
Hifine
Immedia
JB Systems
KAB USA
Kenwood
Klangtraum
Kyocera
Kuzma
Lenco (STL)
Linn
Lorricraft
Loth-X
Marantz
Make one deck
Mel Audio
Michell Engineering
Micro-Seiki
Morsiani
Music Hall Audio
Musical Fidelity
Nad Electronics
Nakamichi
Japanese manufacter
Nottingham Analogue
Numark
Omnitronic
Opera Audio
Oracle
Origin Live
admin- Convidado
Tópicos similares» LOJA DE DISCOS DE DUELO
» Directório de marcas de gira discos - P a Z
» Directório de marcas de gira-discos.....A
» Directório de marcas de gira discos - G a O
» Directório de marcas de gira discos - B a F
