HOW TO... Choose the right size of TV
Mensagem  falp em 29/11/2007, 14:27
HOW TO... Choose the right size of TV drunken
Oct 16, 2007
When it comes to TVs, one thing is for sure - size matters. For some, bigger is better, while others are horrified by the idea of being pinned to the sofa by an image so large you find yourself gazing at a movie character with a head five times the size of your own. So what, really, is the best way of deciding on the size of your new TV?
Thankfully, the way to decide the right size of set for you is very straightforward: all you need to consider is the dimensions of the room in which the set is going to go, and exactly where the TV is going to sit in relation to your favourite armchair.
Simply measure the distance from your much-loved couch potato spot – sorry, 'viewing position' – to the screen itself, then consult the diagram below to discover which size of flatscreen is right for you.
As you can see, a 42in set – or larger – will only be considered optimum if your viewing position is at least four metres from the screen. Sit closer than that, and even with the best sets you may spot picture flaws that compromise your viewing pleasure.
If your favourite comfy sofa spot is 3.5 to 4 metres from that lovely LCD or plasma panel, then a screen of between 36in and 42in will be ideal. a 2.5 to 3.5 viewing distance makes a screen of 28in to 32in the most desirable, while if you sit any closer than that, you should be looking at a maximum screen size of 26in.
Of course, once you've found the right size of set, there are other things you should do to optimise your TV's performance. First and foremost, try to get your screen at eye level. Many TV stands place the screen too low - but the modern trend for wall-mounting flatscreens over fireplaces can lead to quite the opposite effect.
In addition, a good kit rack won't just get the set at the right height - it'll also improve your picture quality. Second, to minimise reflections, avoid any direct light sources behind or above the screen.
Lastly, If you've spent big money on a new telly, be sure to spend a few hundred on a good aerial installation and some high-quality cable. Decent video cables are also essential buys. If you get all that lot right, you can be sure you've got a TV that isn't just a star in the showroom, but one that works brilliantly in your home.
falp
falp
Número de Mensagens : 1301
Pontos/Reputação : -15
Re: HOW TO... Choose the right size of TV
Mensagem  Orion em 4/12/2007, 01:50
É uma boa orientação, sim senhora.
O meu plasma de 42', encontra-se precisamente, quase a 4m. E está muito bem, para mim, é o ideal.
Número de Mensagens : 4623
Pontos/Reputação : 2572
Mensagem  falp em 12/12/2007, 20:37
A 2.5~3m tenho 32"... se mudar é para 37"...Cool
falp
falp
