MED600X3D Media player 3D ( REVIEW Novo modelo 2012/2013)
MED600X3D Media player  3D ( REVIEW Novo modelo 2012/2013) Empty MED600X3D Media player 3D ( REVIEW Novo modelo 2012/2013)
Mensagem  chefeze em 30/11/2012, 02:17
MED600X3D MEDIA PLAYER 3D REVIEW
Pois e´a empresa Mede8er acaba de lançar um novo media player com o chip realtek 1186 versao 3D e´ um media player com as mesma caracteristicas do Med1000x3D.
MED600X3 VS MED1000X3D
Sem drive interna
Sem coaxial
Sem jack infravermelhos
Sem porta usb slave 3.0
MED600X3D Media player  3D ( REVIEW Novo modelo 2012/2013) 600x3d
Processor: RDT1186 - 750Mhz - 512MB SLC Flash - 512MB DDR3 SDRAM
Video Fomats Supported: AVI/BDMV Light/BDISO Light/MKV/TS/TP/TRP/M2TS/MPG/MP4/MOV/DiVX/M4V/VOB/ISO/DAT/WMV/ASF/RM/RMVB/FLV resolution up to 720p/1080i/1080p
3D Video: Full 3D/Side By Side/Top & Bottom/Frame Sequential/Frame Packing.
Audio Codec Supported: MP3/MP2/OGG Vorbis/PCM/LPCM/AAC/RA/Dolby True HD - DTS MA Passthrough on HDMI/AC3 - DTS 5.1/Flac up to 24bit 192Khz/WAV/WMA Standard (DRM & Advanced Profile not Supported)
Photo format Supported: JPEG/BMP/GIF/TIFF/PNG
File System Supported: FAT32/NTFS/HFS+ (MAC)
Video Output Resolution: NTSC/PAl/480P/576P/720P/1080i/1080p/1080p 24Hz input
Output: HDMI 1.4/Component Video/Composite Video/ Stereo RCA/SD/SDHC/Sony Pro Duo Card Slot/SPDIF Optical/Host USB USB 2.0 x2
Optional WiFi: MED10WFB or MED20PCIE (Wifi is optional unless otherwise stated on the packaging)
Contents: MED600X3D(Or MED600X3D-WP)/RC/2x AA Batteries/AC Adapter/HDMI 1.4 Cable/AV Cable/Manual.
Specifications subject to change without notice, DTS, DTS-HD the symbol & DTS or DTS-HD and the Symbols together are registered trademarks of DTS, Inc ©DTS Inc. All Rights Reserved
MED600X3D Media player  3D ( REVIEW Novo modelo 2012/2013) Backrq
• Full 3D - HDMI 1.4 - Play 3D BD-ISO
• Fanless Design
• Active Backlit Remote with Self Learning Hot
Button
• Mede8er Developed Movie & Music Jukebox -
Database Driven
• Web Services, YouYube XL, Web Browser
• Community Skins and Easy Backdrop
Customization
• HD Audio - 7.1 DTSMA & Dolby True HD
• Music JukeBox Local & Network Support
• Built In View Manager (5 Custom views)
• Compatible with Mac HFS+ USB Drives
• Movie XML Med Data in Media Library
• Video JukeBox XML Search Function
• Hard Drive Spin Down Function
• Alpha Search in Media Library
• External Hard Drive Up to 3TB
• Built in Favourites Manager
• Internet Media Strams
• Social Media
• Watches Indicator
• Built in Web Browser
• Internet Radio (SHOUTcast)
• Full Parental Control on Folders
• SD Card slot / Sony Pro Duo Card Slot
• Samba Server - NAS Storage
• Photo slide show with background music
• Subtitle: SRT, SSA, SUB, SMI format
• Network - Ethernet 10/100/1000* Mbps port
• Optional Wi-Fi (802.11b/g/n up to 300Mbps)
Included in Model: MED600X3D-WP
MED600X3D Media player  3D ( REVIEW Novo modelo 2012/2013) Med600x3dnews
Este media player 600X3D vai usar o mesmo firmware do seu irmao mais velho, o X1000X3D sendo que usa o mesmo chip, as qualidade de playback seram as mesmas ou seja bug free.
A vantagem deste media player sera sem duvida o seu preço apelativo de 139€, uma pechincha para o que deve vir a fazer em performance, sem duvida uma exelente compra, mesmo sem a hard drive interna e a porta usb 3.0 slave.
chefeze
chefeze
Número de Mensagens : 60
Interesses : gadgets-cinema 3D-musica
Data de inscrição : 17/10/2012
Pontos/Reputação : 119
https://www.facebook.com/groups/227400017313546/
MED600X3D Media player  3D ( REVIEW Novo modelo 2012/2013) Empty Re: MED600X3D Media player 3D ( REVIEW Novo modelo 2012/2013)
Mensagem  chefeze em 30/11/2012, 02:30
E´com muito agrado que vou receber uma unidade de testes do MED600X3D em primeira mao, vinda directamente do fabricante, para uma review exclusiva na europa no forum audiopt.net, recebi hoje o email da DHL com a confirmaçao do envio.
chefeze
chefeze
Mensagem  chefeze em 30/11/2012, 02:33
Andei ocupado neste dias porque ouve uns testes a fazer na patch de testes do mede8er.
Conseguiram aumentar novamente a capacidad streaming em samba a ler BR ISO 3D .
TESTES RAW
Fiz um teste com nova patch com a frame correcta a 23,976 + hd audio e correu 5 estrelas , em breve saira uma versao de firmware com este bug resulvido, tem um playback suave, suave , suave.
UPNP / DLNA
Quem tiver um PC /NAS /UNRAID /WHS com dlna server pode ver os filmes no formato MKV + HD audio atraves de UPNP no Med600X3D ou Med1000x3D na maxima qualidade possivel.
Testei hoje varios blurays 2D.MKV de 30gb cada um e funciona a maneira com legendas, frames etc ( e sem transcoding ) amanha testo uns BD 3D que estou a preparar.
Portanto alem de samba e NFS junta-se mais uma opçao o upnp/dlna para streaming.
chefeze
chefeze
Mensagem  chefeze em 4/12/2012, 16:39
o media player MED600X3D ja chegou, pronto para ser testado ate ao limite
MED600X3D Media player  3D ( REVIEW Novo modelo 2012/2013) 100680
bastante pequena e leve, nao maior que uma pequena apple tv
MED600X3D Media player  3D ( REVIEW Novo modelo 2012/2013) Img6513h
comparando no tamanho com o iphone 4
MED600X3D Media player  3D ( REVIEW Novo modelo 2012/2013) 100681
acho que deve ser do mesmo tamanho que a media player med450x2 , mas agora sem hard drive interna e um chipset 1186 3D
espreitando pela ventilaçao, ve-se que tem bastante espaço por dentro, tenho a certeza que sera uma unidade com bom arrefecimento
review nos proximos dias .
chefeze
chefeze
Mensagem  Julião em 5/12/2012, 22:52
MED600X3D Media player  3D ( REVIEW Novo modelo 2012/2013) 16044
Interessante, e que tal é a sonoridade disso ?
Julião
Julião
Número de Mensagens : 278
Interesses : Muita musica
Pontos/Reputação : 477
Mensagem  rlcs1958 em 21/12/2012, 15:24
E o som, e o som? bounce
rlcs1958
rlcs1958
Número de Mensagens : 158
Ocupação : Direcção de Obras
Pontos/Reputação : 255
Mensagem  med600 em 4/1/2013, 22:42
Boas chefeze. Para quando essa nova patch com a frame correcta a 23,976 ?
Cps.
M.J.
med600
Número de Mensagens : 3
Data de inscrição : 04/01/2013
Pontos/Reputação : 7
Mensagem  med600 em 21/1/2013, 23:33
Boas chefeze. Ainda andas por ai?
med600
