MED1000X3D media player versao 3D (REVIEW)
MED1000X3D  media player versao 3D (REVIEW) Empty MED1000X3D media player versao 3D (REVIEW)
Mensagem  chefeze em 29/11/2012, 23:25
MED1000X3D Media Player 3D REVIEW
venho aqui dar conhecimento de um dos melhores media players do mercado, ja uso esta unidade deste setembro deste ano com excelentes resultados a nivel de HD audio e de leitura de filmes blu-ray seja em 2D ou 3D ino formato ISO ou MKV
Caracteristicas do MED1000X3D :
- Full 3D - HDMI 1.4 - Play 3D BD-ISO
- Complete Aluminium Die Cast Casing - Fanless Design
- Mede8er Xbay - Easy Hard Drive Change - Up to 3 TB
- Active Backlit Remote with Self Learning Hot Button
- Mede8er Developed Movie & Music JukeBox - Database Driven
- Web Services, YouTube XL , Web Browser
- Built in Mede8er Favourites Manager
- Community Skins and Ways Backdrop Customization
- HD Audio - 7.1 DTSMA & Dolby True HD
- Fast USB 3.0 & Gbit Network Port
- 0dB Noise excluding internal Hard Drive
MED1000X3D  media player versao 3D (REVIEW) Img6051i
•Processor: RTD1186
• 750Mhz • 512 SLC Flash
• 512 DDR3 SDRAM
•Video Formats Supported: AVI / BDMV Light / BDISO Light / MKV / TS / TP / TRP / M2TS / MPG / MP4 / MOV / M4V / VOB / ISO / IFO / DAT / WMV / ASF / RM / RMVB / FLV resolution up to 720p / 1080i / 1080p
•3D Video: 3D BDISO, Side by Side, Top & Bottom, Frame Sequential, Frame Packing
•Video Codecs Supported: MPEG-1-2 / MPEG-4 SP /ASP /AVC (H.264) / XviD / DivX / WMV9 (VC-1) / RealVideo 8/9/10 (up to 720P)
•Audio Codec Supported: Mp3 / Mp2 / OGG Vorbis / PCM / LPCM / AAC / RA / Dolby True HD - DTS MA Passthrough on HDMI / AC3 - DTS 5.1 / FLAC up to 24bit 192Khz / WAV / WMA Standard (DRM, & Advanced Profile not supported)
•Photo format Supported: JPEG, BMP, GIF, TIFF, PNG File System Supported: FAT32, NTFS, HFS+ (Mac) Video output resolution: NTSC, PAL, 480p, 576p, 720p, 1080i, 1080p, 1080p 24hz Input /
•Outputs: HDMI 1.4 Component Video Composite Video Stereo RCA
• SD SDHC Sony Pro Duo Card Slot
• SPDIF Optical • Co-Ax Digital • Slave Port USB 3.0, HOST Port x 2 USB 2.0
• IR Jack
•Optional WiFi: MED10WFB or MED20PCIE (WiFi is optional unless otherwise stated on the packaging) •Optional Hard Drive: Internal Hard Drive is optional unless otherwise stated on the packaging. •Contents: MED1000X3D, RC, 2 x AA Batteries, AC Adapter, HDMI 1.4 Cable, AV Cable, USB3.0 Cable, HDD Securing Screws.
Specifications subject to change without notice.
DTS, DTS-HD, the Symbol, & DTS or DTS-HD and the Symbol together are registered trademarks of DTS, Inc. © DTS, Inc.
MED1000X3D  media player versao 3D (REVIEW) Img6052w
Última edição por chefeze em 30/11/2012, 02:09, editado 2 vez(es)
chefeze
chefeze
Número de Mensagens : 60
Interesses : gadgets-cinema 3D-musica
Data de inscrição : 17/10/2012
Pontos/Reputação : 119
https://www.facebook.com/groups/227400017313546/
MED1000X3D  media player versao 3D (REVIEW) Empty Re: MED1000X3D media player versao 3D (REVIEW)
Mensagem  chefeze em 29/11/2012, 23:35
A unidade suporta hard drive interna ate 4TB cada e pode suportar mais 2 hard drives atraves da porta USB
Umas fotos para comparaçao com outros media player nomendamente o micca EP950 e o med450x2
MED1000X3D  media player versao 3D (REVIEW) Img6047c
MED1000X3D  media player versao 3D (REVIEW) Img6048b
MED1000X3D  media player versao 3D (REVIEW) Img6049l
a unidade e´em aluminio de boa construçao e apesar de nao ter ventoinha tem uma boa ventilhaçao mantento as hard drives a uma temp segura .
nesta imagem sao as portas usb 2.0
MED1000X3D  media player versao 3D (REVIEW) Img6053w
aqui pode-se ver a porta usb 3.0 (slave) que se liga ao pc para copiar conteudo para a hard drive interna do x3.
MED1000X3D  media player versao 3D (REVIEW) Img6054z
as diversas ligaçoes hdmi 1.4 , porta ethernet, saida coaxial,optical , video composto e power.
MED1000X3D  media player versao 3D (REVIEW) Img6050h
o manual
MED1000X3D  media player versao 3D (REVIEW) Img6055bu
e o comando
MED1000X3D  media player versao 3D (REVIEW) Img6056x
chefeze
chefeze
Mensagem  chefeze em 30/11/2012, 00:14
Configuraçao do GUI
Quando ligamos o x3 pela primeira vez apenas configuramos os settings basicos como a hora, lingua e o acesso a internet, recomendo colocar um ipfixo na configuraçao.
Aqui temos o menu inicial com os favoritos, biblioteca, youtube xl, acesso a serviçoes de internet e setup
MED1000X3D  media player versao 3D (REVIEW) Img6385yr
no system temos diversas opçoes, mas de vindo de origem nao vai ser necessario mudar nenhuns settings
MED1000X3D  media player versao 3D (REVIEW) Img6386f
nas opçes de audio coloca-se hd audio 5.1/7.1 se tiverem um sistema em casa que o suporte e hdmi ouptut
MED1000X3D  media player versao 3D (REVIEW) Img6387o
nas configuraçes de video remomenda- se as da foto para uma leitura suave
MED1000X3D  media player versao 3D (REVIEW) Img6388z
definiçoes de network, tambem nao sera necessdario modificar muito.
MED1000X3D  media player versao 3D (REVIEW) Img6389k
no misc apenas a destacar a opçao de salvar os settings numa pen
MED1000X3D  media player versao 3D (REVIEW) Img6390eh
Última edição por chefeze em 30/11/2012, 00:29, editado 1 vez(es)
chefeze
chefeze
Mensagem  chefeze em 30/11/2012, 00:28
Settings com cabo HDMI ligado a um Receptor AV
system
resume play to off
cec -on , one touch stanby on
menu BD OFF
all the others default
audio
hdmi passthrough
spdif passthrough
surround sound true hd dts-hd 7.1
lips sync auto
video
16:9
hdmi auto
1080p 24 hz on
auto framerate on coloquem on se o conteudo 2D fizer output de 60hz
plasma mode off
screen size ( aqui podem ajustar o vosso ecran ajustando as linhas vermelhas )
network
samba on
all the other default
Settings com cabo HDMI ligado directamente numa aTV
system
resume play to off
cec -on , one touch stanby off
menu BD OFF
audio
hdmi downmix 2ch ou hdmi auto
spdif passthrough
force ac3 on (apenas na versao v1.03 21setembro ou superior )
surround sound ac3/dts 5.1 ou don't care
lips sync auto
video
16:9
hdmi auto
1080p 24 hz on
auto framerateon coloquem on se o conteudo 2D fizer output de 60hz
plasma mode off (Se usarem uma tv plasma coloquem on)
network
samba on (no caso de terem filmes em rede ou partilha)
Teclas do comando
aconselha-se a ler o manual para perceber as funçoes do comando, mas e´muito facil de usar, apenas vou destacar alguma teclas que sao importantes
tecla I - mostra a informaçao durante o playback e tambem acede a jukebox
tecla F3- desliga o menu dos filmes
ps: devido ao licenciamento do menu java dos blu-rays todos os aparelhos que queiram ter a licenca java, teem de vir com cinavia incorporada, visto que este media players da china nao o trazem cinavia apenas suportam menu bd lite1.0 o que em blu-rays mais recente o menu nao funciona, logo a visualizaçao vai directo para o filme a tecla F3 liga/ desliga o menu dos filmes.
chefeze
chefeze
Mensagem  chefeze em 30/11/2012, 01:02
MEDIA LIBRARY e JUKEBOX
No menu da biblioteca existem varias opçoes de visualizaçao o x3 suporta os seguintes formatos para lerem o conteudo das hard drives.
USB..............velocidades ate 480mbps
SAMBA..........streaming de PC , NAS, unraid ou windows home server ate 90mbps
UPNP/DLNA... streaming de Pc , NAS, unraid ou windows home server ate 90mbps
NFS............... streaming de Pc ,NAS, unraid ou windows home server acima de 120mbps
ps: Nas synology estao limitadas no protoclo NFS v2 com RSIZE 8K o que limita a velocidade em streaming de NFS ate 65mbps
MED1000X3D  media player versao 3D (REVIEW) Img6391rd
O med1000x3d tem varios modos de visualizaçao da biblioteca um exemplo de como esta a minha biblioteca de filmes criado com Dunex e o Dunextomede8er para mac.
MED1000X3D  media player versao 3D (REVIEW) Img6392l
carregando na tecla I do comando temos acesso a uma imagem mais detalha das caracteristicas do filme
MED1000X3D  media player versao 3D (REVIEW) Img6394u
MED1000X3D  media player versao 3D (REVIEW) Img6395r
MED1000X3D  media player versao 3D (REVIEW) Img6396gd
a biblioteca tambem suporta pesquiza de conteudo atraves de XML SEARCH
MED1000X3D  media player versao 3D (REVIEW) Img6410nb
LEITURA DE CONTEUDOS
durante o playback e´possivel aceder a diversas opçoes tais como a framerate, legendas ,audio etc
MED1000X3D  media player versao 3D (REVIEW) Img6397ph
MED1000X3D  media player versao 3D (REVIEW) Img6398ki
MED1000X3D  media player versao 3D (REVIEW) Img6402mk
este media players por definiçao leem a playlist com maior GB se for o caso de terem variasnum ficheiro ISO, por vezes em titulos versao do realizador nao e´o filme correcto, para isso existe a opçao durante o playback de escolher a playlist correcta do filme, vejam a opçao playlist na foto.
e ainda existem mais opçoes como simulaçao 3D e leitura 3D side by side e top and bottom, assim como os video setting.
MED1000X3D  media player versao 3D (REVIEW) Img6411n
chefeze
chefeze
Mensagem  chefeze em 30/11/2012, 01:33
JUKEBOX Y2M WINDOWS
Nao vou postar como criar a jukebox porque ja existem tutoriais feitos em portugues no site MEDE8ER.
Seguindo este tutorial Y2M movies podem criar a vossa biblioteca de filmes facilmente, e aqui teem um tutorial Y2M para musica caso utilizem o x3 para esse fim.
O Y2M e´muito simples de usar
JUKEBOX MAC
Se forem utilizadores MAC como eu fazem o download do duneX e do DuneXtomede8er basicamente o duneX cria e coloca as imagens e o duneXtomede8er adicoona o ficheiro XML para poderem fazer a pesquiza se o desejarem
Ainda mais simples de usar do que no windows.
deveram ficar com algo como isto no ficheiro individual de cada filme.
No caso de adicionarem legendas externas colocam o nome da legenda da seguinte forma:
avatar.iso
avatar.pt.srt
ou
avatar.mkv
avatar.srt
MED1000X3D  media player versao 3D (REVIEW) Img6412z
para ter este belo resultado
MED1000X3D  media player versao 3D (REVIEW) Img6408v
SKIN PACKS
Podem alterar a visualizaçao do vosso x3 com uns skins packs criados para o efeito.
No forum Mede8er podem fazer o download de 12 skins packs criados pelos moderadores e membros desta comunidade
LINK SKIN PACKS
chefeze
chefeze
Mensagem  chefeze em 30/11/2012, 02:07
CONCLUSAO
UPGRADE DE FIRMWARE
existem 2 modos de upgrade de firmware que tambem esta explicado no manual
1- donwload de ficheiro iso ou rar no forum meddler ( se usarem mac vem directo como img.)
2- opçao 1 transferir img. para uma pen formatada em fat32 ou ntsf > ligar ao x3> setup >misc > usb upgrade
3- opçao 2 reset de todas as configuraçoes >mesmo processo anterior > desligar x3 > ligar pen usb > carregar 15 segundo no botao power e tirar, esperar que processo termine > ok
o forum mede8er tem bastante suporte ao firmware do aparelho, desde que saiu em setembro de 2012 todos os bugs foram resolvidos, fazendo deste media player um dos melhores que se pode comprar actualmente, quer se goste de 3D ou nao.
Faço parte de um grupo voluntariamente criado de beta testers no forum mede8er e temos acesso em primeira mao ao firmware/patch para testar, tentando encontrar bugs existentes, novos firmware com bugs resolvidos sao lançados assim que existam condiçoes.
A ultima novidade que sera implementada na proximas semanas no firmware e´a resoluçao da tao esperava correçao da framerate a ler em 23,976 em 2D ou 3D ...um bug que afligiu muitos media players com chipset 1186 .
Mesmo assim a imagem do x3 e´completamente suave a ler em 23,99fps, mas em breve sera ainda melhor como ja tive oportunidade de testar.
podem comprar este media player no site mede8er.eu ou em inforphone.pt que e´ o representante para portugal, tem um preço de 200€ e com 5 anos de garantia
PS: Nao tenho qualquer afinidade ou interesse comercial com a empresa MEDE8ER ou com a INFORPHONE, sou apenas um entusiasta deste tipo de aparelhos, fiz a review de livre e espontanea vontade, espero que tenham gostado, qualquer duvida estou aqui para ajudar
PS1: muito dos utilizadores que por aqui passam talvez ja tenham visto flashes desta review porque ja a tinha feito noutro forum de audio.
chefeze
chefeze
