Filtros DacMagic
Filtros DacMagic
Para os utilizadores do DacMagic, e não só, venho questionar qual, em vossa subjectiva opinião, será o melhor filtro?
Retirado do site da CA, deixo a seguinte informação:
The DacMagic’s 32 bit DSP runs Cambridge Audio’s own proprietary digital filter algorithms with three different filter options available: Linear Phase, Minimum Phase and Steep. Controlled from one switch on the front panel, they are extremely clever audiophile topologies specifically developed for audio playback and all offer excellent sound quality but differ slightly to appeal to a wide range of listening tastes.
Linear phase is the same as used in the flagship Azur 840C upsampling CD player. It uniquely features ‘constant group delay’ which delays all audio signals at all frequencies by the same amount meaning all audio is fully time-coherent at the output.
Minimum phase meanwhile does not feature constant group delay but rather the co-efficients have been optimized without feed-forward so that the impulse response exhibits no pre-ringing in the time domain. Some commentators have argued that the pre-ringing as seen in nearly all digital filter designs may affect the transient attack of percussive instruments. Minimum phase implementation eliminates this and is a technology only seen previously in some extremely highend CD playback systems.
Lastly, the steep filter removes close in aliasing artefacts by re-calibrating the co-efficients for a very slight roll off at 20kHz but an ultra steep drop to the stop-band just after 20kHz.
These three filters are all of the highest quality but offer subtle differences for the user to enjoy. The type of filter chosen is remembered for each input individually so that it is possible to use one for PC playback via USB and another for CD playback via SPDIF.
Na minha opinião pessoal, as diferenças entre os filtros são mesmo muito mínimas.
No entanto, daquilo que me apercebo:
Linear Filter: Som muito limpo, e parece um pouco mais "arejado" (menos atenuação das HF).
Minimum Filter: Som mais quente, mais semelhante ao analógico, com grande musicalidade, mas parece-me que perde um pouco de detalhe
Steep Filter: Não tenho uma opinião formada sobre este filtro, sendo o que menos tempo ouvi.
Desde o terceiro dia de utilização do DacMagic que fixei o filtro no Minimum para ambas as fontes utilizadas. No entanto, ontem, experimentei o Linear, e estava a gostar...
Por último, e um pouco mais técnico e não tão subjectivo, vem a questão da inversão da fase. Penso que não se deverá utilizar, no entanto encontrei o seguinte artigo:
http://www.gcaudio.com/resources/howtos/absolutephase.html
Para os mais entendidos, faz sentido experimentar esta opção, sem que se tenha qualquer noção se a fase surge invertida ao DAC por um outro qualquer elemento na cadeia?
Estes assuntos, apesar de se encontrarem pela "net" surgem de forma dispersa. Nada melhor que a nossa comunidade para abordar a questão!
_nimitz_- Membro Audiopt
- Número de Mensagens: 272
Ocupação: IT
Interesses: Musica
Data de inscrição: 28/02/2011
Pontos/Reputação: 397
Re: Filtros DacMagic
Ninguém?!
O pessoal já está todo de férias, ou o pessoal dos DacMagic não tem opinião definida sobre os filtros...como eu
Ocupação: IT
Interesses: Musica
Na minha opinião esta história dos filtros "para temperar o som ao gosto do cozinheiro" não passa de marketing.
Como sempre, aconselho a leitura do teste (avaliação técnica) da Stereophile:
http://www.stereophile.com/content/cambridge-audio-azur-dacmagic-da-converter-measurements
Segundo o teste, e ao contrário do que afirma o fabricante, o filtro de forte inclinação (steep) não produz qualquer alteração na resposta de frequências.
Por outro lado, filtro de fase mínima (minimum phase) comporta-se conforme a descrição mas agora se a diferença é ou não audível já não sei dizer.
- Número de Mensagens: 2614
Tópicos similares» Filtros DacMagic
» meu 2º sistema (soundzen 2008)
» Utilização de filtros de corrente com amplif. a valvulas
» FILTROS OU LENTES MACRO E CLOSE-UP
» Filtros ND
» Filtros ND
