Colunas Magneplanar 1.7
Colunas Magneplanar 1.7 Empty Colunas Magneplanar 1.7
Mensagem  VilaSound em 10/1/2011, 17:21
As Magneplanar 1.7 encontram-se em demonstração na VilaSound durante o mes de Janeiro.
Características: 3 vias, Full-Range, Quasi-Ribbon; Resposta frequência 40-24 kHz; Sensibilidade 86dB/500Hz /2.83v; Impedância 4 Ohm. Acabamentos alumínio cinza ou preto e madeira. Acabamentos tecido: branco, cinza ou preto
Tecnologia quasi-ribbon: http://www.magnepan.com/magneplanar_technology
«They are intoxicatingly realistic. There is something about Maggies that simply sounds like the real thing, particularly in the midrange, particularly on voices. Maggies aren’t the only speakers that have this supreme gift (Magicos have it, too—in spades--and so do CLXes). But some combination of neutrality, coherence, transient speed, image size, dispersion, dimensionality and bloom, and resolution of texture has always made Maggies sound more real than a large percentage of their competition. Here—with the right recordings, at the right levels—that realism (at least in the midband) is very nearly as close as I’ve come to the absolute sound in my listening room, and simply unmatched for a speaker at this price point (or, really, anything even remotely close to its price point).»
de: http://www.avguide.com/blog/magneplanar-17-first-listen
Review HIFI Clube:
http://www.hificlube.net/Sections/Details.aspx?articleID=23496§ionID=1
Última edição por VilaSound em 31/1/2011, 17:28, editado 1 vez(es)
Gustavo Rosa
www.vilasound.pt
www.facebook.com/vilasound
VilaSound
VilaSound
Número de Mensagens : 188
Pontos/Reputação : 324
http://www.vilasound.pt
Colunas Magneplanar 1.7 Empty Re: Colunas Magneplanar 1.7
Mensagem  VilaSound em 31/1/2011, 16:45
Com o objectivo de montar um sistema "Budget High-End", em colaboração com a Esoterico, estamos agora também a usar amplificação NAD (C375 BEE) com resultados surpreendentes Shocked
Gustavo Rosa
www.vilasound.pt
VilaSound
VilaSound
Mensagem  francisco chaves em 31/1/2011, 16:51
VilaSound escreveu:As Magneplanar 1.7 encontram-se em demonstração na VilaSound durante o mes de Janeiro.
Review HIFI Clube: http://www.hificlube.net/Sections/De...96§ionID=1
O site referenciado do hificlube não funciona, deve haver algum problema momentâneo
francisco chaves
Número de Mensagens : 172
Interesses : Música, Viajar e conhecer novos povos
Data de inscrição : 20/12/2010
Pontos/Reputação : 265
Mensagem  VilaSound em 31/1/2011, 17:29
Obrigado. Rectificado.
Gustavo Rosa
www.vilasound.pt
VilaSound
VilaSound
