Merrill Williams Audio R.E.A.L. turntable
http://www.realturntable.com/
The all-new Merrill Williams Audio R.E.A.L. turntable ($4000) claims to add a new dimension to vinyl replay with such items as their "R.ubber E.lastomer A.coustic L.aminate and Energy Isolation Valley". This turntable design also features inverted hemispherical damping feet to reduce unwanted vibrations and a suspended plinth. According to Merrill Williams Audio, this is "the most dramatic improvement in turntable design in 30 years! The patented R.ubber E.lastomer A.coustic L.aminate controls self generation and external energies to a degree never before accomplished." All of the active parts such as the motor, tonearm and spindle/bearing assembly are positioned on an acoustically neutral Isolation Damping Elastomer Plinth Core. The feet act as a damping suspension (hence suspended plinth) and a second layer of isolation is provided by the plinth elastomer. The R.E.A.L turntable has an elastomer suspended graphite impregnated oil well bearing, 0.75-inch polished stainless steel spindle and an elastomer suspended azimuth adjustable tonearm mounting platform. A specialized Bakelite resin composite platter and rubber cork compound mat provide a special surface for your vinyl record. A ground plane plinth, outboard power transformer plus optional crystal time base adjustable speed control ensure speed stability of your vinyl playback. An optional periphery clamping ring and center weight are available.
Os novos gira-discos Williams Merrill Audio R.E.A.L. (4.000 dólares) afirma adicionar uma nova dimensão para reproduzir vinil seus "R.ubber E.lastomer A.coustic L.aminate e Energia Isolamento Valley". Este projeto também apresenta plataforma giratória invertida de amortecimento hemisférica pés para reduzir as vibrações indesejadas e um plinto suspenso. Segundo a Merrill Williams áudio, esta é "a melhoria a mais dramática no projeto gira-discos em 30 anos! A tecnologia patenteada R.ubber E.lastomer A.coustic L.aminate controla a geração própria e energias externas a um grau nunca antes alcançado." Todas as peças ativas, como o motor, tonearm e montagem / rolamento do eixo são posicionados em um isolamento acústico de amortecimento Elastômero neutro Plinth Core. Os pés funcionam como uma suspensão de amortecimento (daí suspensa base) e uma segunda camada de isolamento é fornecido pelo elastômero plinto. A verdadeira placa giratória tem um elastômero suspensa grafite impregnada de poço de petróleo tendo, de 0,75 polegadas do eixo em aço inox polido e um elastômero plataforma suspensa tonearm azimute de montagem ajustável. Um prato de resina composta especializada baquelite e borracha esteira de aglomerado de cortiça proporcionar uma superfície especial para o seu disco de vinil. Um plinto plano terreno, motor de popa transformador de potência, mais opcionais cristal do tempo base de controle de velocidade ajustável garantir a estabilidade da velocidade de sua reprodução em vinil. Um anel de aperto opcional periferia e centro de peso estão disponíveis.
Traduzido pelo google
- Número de Mensagens: 5423
Pontos/Reputação: 3046
Tópicos similares» Hayley Williams
» Merrill Williams Audio R.E.A.L. turntable
» dac magic-camb audio
» Monitor Audio RS6 vs B&W 684 vs ..
» Cambridge Audio Azur 640C
