Últimos assuntos Quem está conectado Há 5 usuários online :: 1 usuário cadastrado, 1 Invisível e 3 Visitantes Usuários registrados : Melo [ Ver toda a lista ] O recorde de usuários online foi de 53 em 27/1/2008, 22:27 Estatísticas Temos 1075 usuários registradosO último usuário registrado atende pelo nome de DNunes Os nossos membros postaram um total de 40252 mensagens em 3990 assuntos | KRELL18/6/2008, 23:01 por bluemonday ![]() Novo processador de surround da krell. O 707 é capaz de oferecer um output até 12 canais ! , sendo 2 para canais centrais e suporte para 4 subwoofers (8.4) . Feito em alumínio , usa o DAC Crystal CS497004 , suporta HDMI 1.3 para descodificar Dolby True HD , DTS HD Master Audio e ainda 2 DSPs a 64-Bits para uma excelente precisão na descodificação do sinal. FEATURES Supports Dolby Digital Surround EX, Dolby Digital 5.1, DTS 6.1 ES, DTS 5.1, DTS NEO:6, Dolby Pro Logic II processing as well as Dolby TrueHD and DTS HD Master Audio lossless surround formats over HDMI 1.3, plus nine proprietary Krell Music Surround modes Digital processing circuitry runs in double precision mode at a word length of 64-bits for the most precise division of frequencies and optimization of the system's speaker/subwoofer combination. Twelve output stages are fully balanced and feature Krell Current Mode topology with 1.5 MHz of bandwidth for accurate reproduction of the today’s demanding movie soundtracks. Evolution CAST outputs are supported for all 12 channels. Current Audio Signal Transmission (CAST) is a proprietary method of sending the audio signal between components in the current domain, from a high impedance transmitter to a low impedance receiver. Krell components connected in Evolution CAST act together as an electrically unified whole, free from the deleterious effects normally imposed by the connecting cables. Preamp mode bypasses all digital circuitry and routes the analog input, stereo or 7.1 multi-channel, directly to the volume control for the purest path possible. Separate power supplies for digital and analog circuit paths are linear design and feature custom made, low-noise transformers and robust regulation Remote control options include bi-directional RS-232 communication, mutliple 12 VDC triggers, and a direct RC-5 input. The all-discrete video circuitry bandwidth provides pristine pass-through of all progressive and wideband high definition signals including HDMI. Inputs and outputs for composite, S-Video, component, and HDMI 1.3 are supported. On Screen Display set-up and status are available on all video outputs, all of the time, including upconversion to component and HDMI progressive outputs. Any SD or HD video standard may be converted up to 1920 x 1080p 60 Hz. Custom, all-aluminum chassis boasts impeccable fit and finish. FONTE : KRELL Comentários: 0 |
